Einleitung
If your laptop is not powering on or is not holding a charge, a faulty battery could be the issue. Before starting this guide, it may be helpful to have a secure place to put the screws after they have been removed.
Was du brauchst
Remove the two 3mm Phillips #0 screws on the bottom of the computer that secure the plastic backing.
Pull the bottom plate towards yourself until it unhinges fully.
Once the plate is free from the backing remove it completely.
Pull the blue tab towards yourself until you hear a click.
Once the blue tab is released, pull up on the battery.
Once the battery can move freely, take it out completely.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
