Zum Hauptinhalt wechseln
Sony Vaio VGN-TXN25N Keyboard Replacement
Was du brauchst
  1. Sony Vaio VGN-TXN25N Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Take out the screw in the center of the computer.
  2. Sony Vaio VGN-TXN25N Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Flip the computer right side up.
    • Open screen so that keyboard is visible.
  3. Sony Vaio VGN-TXN25N Keyboard Replacement: Schritt 3, Bild 1 von 2 Sony Vaio VGN-TXN25N Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Use a plastic opening tool to gently lift the keyboard at a corner.
    • Make sure you get below the keyboard itself and not just the keys.
    • Slide the tool around the perimeter of the keyboard and it will start to lift.
  4. Sony Vaio VGN-TXN25N Keyboard Replacement: Schritt 4, Bild 1 von 2 Sony Vaio VGN-TXN25N Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Do not pull the keyboard away from the computer. There is a ribbon cord attaching the keyboard to the computer.
    • Once the keyboard has been lifted at a few edges, lift the keyboard with both hands.
  5. Sony Vaio VGN-TXN25N Keyboard Replacement: Schritt 5, Bild 1 von 3 Sony Vaio VGN-TXN25N Keyboard Replacement: Schritt 5, Bild 2 von 3 Sony Vaio VGN-TXN25N Keyboard Replacement: Schritt 5, Bild 3 von 3
    • Locate the ribbon cord behind the keyboard.
    • Locate a brown clamp attaching the keyboard to the computer.
    • Use a plastic opening tool to lift the clamp and release the cable.
    • Now the keyboard can be pulled away entirely.
Abschluss
Austen
32 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 5-3, Forte Spring 2012 Mitglied von Cal Poly, Team 5-3, Forte Spring 2012
CPSU-FORTE-S12S5G3
5 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 22
Insgesamt: 2,081
