Zum Hauptinhalt wechseln
Sony Vaio VGN-SR140E Screen Replacement
Was du brauchst
  1. Sony Vaio VGN-SR140E Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E Screen Replacement: Schritt 2, Bild 1 von 1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E Screen Replacement: Schritt 3, Bild 1 von 2 Sony Vaio VGN-SR140E Screen Replacement: Schritt 3, Bild 2 von 2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E Screen Replacement, Screen: Schritt 4, Bild 1 von 3 Sony Vaio VGN-SR140E Screen Replacement, Screen: Schritt 4, Bild 2 von 3 Sony Vaio VGN-SR140E Screen Replacement, Screen: Schritt 4, Bild 3 von 3
    • Remove the rubber pads at all four corners of the screen bezel using a spudger. This will reveal four 5mm Phillips screws.
    • Use a Phillips #1 screwdriver to remove the four screws and set them aside.
  5. Sony Vaio VGN-SR140E Screen Replacement: Schritt 5, Bild 1 von 1
    • Remove the screen's plastic bezel. You may need to use slight pressure to release the clips that secure the bezel to the laptop.
  6. Sony Vaio VGN-SR140E Screen Replacement: Schritt 6, Bild 1 von 2 Sony Vaio VGN-SR140E Screen Replacement: Schritt 6, Bild 2 von 2
    • Lift screen bezel up and off of the laptop.
  7. Sony Vaio VGN-SR140E Screen Replacement: Schritt 7, Bild 1 von 3 Sony Vaio VGN-SR140E Screen Replacement: Schritt 7, Bild 2 von 3 Sony Vaio VGN-SR140E Screen Replacement: Schritt 7, Bild 3 von 3
    • Close the laptop carefully and slowly while holding the screen with your thumb to prevent it from falling.
    • Lay the screen gently on the keyboard. This will reveal the screen's connector.
  8. Sony Vaio VGN-SR140E Screen Replacement: Schritt 8, Bild 1 von 3 Sony Vaio VGN-SR140E Screen Replacement: Schritt 8, Bild 2 von 3 Sony Vaio VGN-SR140E Screen Replacement: Schritt 8, Bild 3 von 3
    • Grasp the connector and gently pull it out.
  9. Sony Vaio VGN-SR140E Screen Replacement: Schritt 9, Bild 1 von 1
    • The screen can now be removed.
Abschluss
Jeremy
722 Reputation
4 Anleitungen geschrieben
Michigan Tech, Team 1-6, Lauer Spring 2015 Mitglied von Michigan Tech, Team 1-6, Lauer Spring 2015
MTU-LAUER-S15S1G6
2 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 1,111
