Zum Hauptinhalt wechseln
Sony Vaio VPCCW17FX Back Case
Was du brauchst
  1. Sony Vaio VPCCW17FX Back Case, Back case: Schritt 1, Bild 1 von 1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Back Case: Schritt 2, Bild 1 von 3 Sony Vaio VPCCW17FX Back Case: Schritt 2, Bild 2 von 3 Sony Vaio VPCCW17FX Back Case: Schritt 2, Bild 3 von 3
    • Remove the battery by pinching the two lock tabs towards the center.
    • Next, lift up on the battery to remove it.
  3. Sony Vaio VPCCW17FX Back Case: Schritt 3, Bild 1 von 1
    • Using a Phillips #00 screwdriver, remove the twenty-two 5.6 mm screws from the back of the laptop.
    • Be sure to remove all screws, including those that are typically covered by the battery.
  4. Sony Vaio VPCCW17FX Back Case: Schritt 4, Bild 1 von 3 Sony Vaio VPCCW17FX Back Case: Schritt 4, Bild 2 von 3 Sony Vaio VPCCW17FX Back Case: Schritt 4, Bild 3 von 3
    • Now, remove the small covers from the back of the case.
    • Using a Phillips #00 screwdriver, unscrew the three 5.6 mm screws from the covers (one screw on the RAM cover [middle] and two screws on the Hard Drive cover [bottom right]).
    • Then, lift up on and remove these covers as shown in the third image.
  5. Sony Vaio VPCCW17FX Back Case: Schritt 5, Bild 1 von 3 Sony Vaio VPCCW17FX Back Case: Schritt 5, Bild 2 von 3 Sony Vaio VPCCW17FX Back Case: Schritt 5, Bild 3 von 3
    • Remove the hard drive.
    • Using a Phillips #00 screwdriver, unscrew the two remaining 4.9 mm screws holding the hard drive into place.
    • Next, lift up and pull outwards to release the hard drive from its socket.
  6. Sony Vaio VPCCW17FX Back Case: Schritt 6, Bild 1 von 1
    • Using your fingers, grasp the black tab and lightly pull up on the ribbon cable to detach it from the motherboard.
  7. Sony Vaio VPCCW17FX Back Case: Schritt 7, Bild 1 von 1
    • After proper removal of all necessary screws, gently lift up on the back case to remove it.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ellie DePorter
310 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 958
