Zum Hauptinhalt wechseln
Sony Vaio VPCCW17FX Hard Drive Replacement
Was du brauchst
  1. Sony Vaio VPCCW17FX Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Slide the two latches towards the center of the battery to release it.
  3. Sony Vaio VPCCW17FX Hard Drive Replacement: Schritt 3, Bild 1 von 2 Sony Vaio VPCCW17FX Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Hard Drive Replacement: Schritt 4, Bild 1 von 2 Sony Vaio VPCCW17FX Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the two 7.7 mm screws from the hard drive cover and place it to the side.
  5. Sony Vaio VPCCW17FX Hard Drive Replacement: Schritt 5, Bild 1 von 3 Sony Vaio VPCCW17FX Hard Drive Replacement: Schritt 5, Bild 2 von 3 Sony Vaio VPCCW17FX Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Remove the four screws (Length: 7.7 mm) using the Phillips #00 screwdriver that hold the hard drive in place.
    • Use the tab to slide the hard drive away from the laptop.
    • Set the disconnected hard drive away from the laptop.
  6. Sony Vaio VPCCW17FX Hard Drive Replacement: Schritt 6, Bild 1 von 3 Sony Vaio VPCCW17FX Hard Drive Replacement: Schritt 6, Bild 2 von 3 Sony Vaio VPCCW17FX Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Remove the four screws (Length: 7.7 mm) using the Phillips #00 screwdriver that cover the hard drive.
    • Use the tab to pull up on the metal cover and remove it.
    • You are now free to replace the hard drive.
Abschluss
Tiffani Beck
219 Reputation
2 Anleitungen geschrieben
Texas Tech, Team S8-G5, Bennett Spring 2017 Mitglied von Texas Tech, Team S8-G5, Bennett Spring 2017
TTU-BENNETT-S17S8G5
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 1,614
