Einleitung
In this guide, you will learn to remove and replace the RAM of a Sony Vaio VPCEA3C5E computer.
Was du brauchst
Push out the two outer white catch pieces holding the both sides of the RAM in position. Begin gently removing the RAM from its position.
Once you have the RAM out on its own, replace it or put it back into the correct position.
Fast fertig!
Abschluss
