Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
The hard drive is essential for saving all of your files and data. Over time, the hard drive performance can start to deteriorate, putting your data at risk. This guide will demonstrate how to properly remove and replace your hard drive for the device.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Be sure to  disconnect the device charger and power down the device before beginning. Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right. Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Slide the  "release" switch to the left  and gently lift the battery up to remove it. Completely remove the battery from the device. Completely remove the battery from the device.
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. The hard drive panel is located in the bottom right corner of the device.
    • The hard drive panel is located in the bottom right corner of the device.
  5. Using the PH #0 screwdriver, unscrew the two  6.5mm screws located in the bottom left and middle right of the panel. The screws remain in the panels. Remove the panel by pulling it up towards yourself.
    • Using the PH #0 screwdriver, unscrew the two 6.5mm screws located in the bottom left and middle right of the panel. The screws remain in the panels.
    • Remove the panel by pulling it up towards yourself.
  6. Using a PH0 screwdriver, remove the four 3mm silver screws located  in the external hard drive cover. Using a PH00 screwdriver, remove the final 3mm black screw located in the top right section of the hard drive cover. Carefully remove the silver hard drive cover.
    • Using a PH0 screwdriver, remove the four 3mm silver screws located in the external hard drive cover.
    • Using a PH00 screwdriver, remove the final 3mm black screw located in the top right section of the hard drive cover.
    • Carefully remove the silver hard drive cover.
  7. Detach the hard drive  by disconnecting it from the motherboard, pulling it gently from left to right. Detach the hard drive  by disconnecting it from the motherboard, pulling it gently from left to right. Detach the hard drive  by disconnecting it from the motherboard, pulling it gently from left to right.
    • Detach the hard drive by disconnecting it from the motherboard, pulling it gently from left to right.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Sean Lyon
378 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S2-G1, Simcock Spring 2018 Mitglied von UMass Dartmouth, Team S2-G1, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G1
3 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 7
Letzten 30 Tage: 21
Insgesamt: 458
