Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
The optical drive needs to be replaced when it stops reading discs. This is a guide to replace the optical drive of a Sony Vaio PCG-61A12L.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Unlock the battery by sliding the lock upwards.
    • Unlock the battery by sliding the lock upwards.
  2. Slide the release upwards and lift out the battery to remove. Once battery is removed, long press the Power button for 30-60s and discharge any remaining power inside of the computer.
    • Slide the release upwards and lift out the battery to remove.
    • Once battery is removed, long press the Power button for 30-60s and discharge any remaining power inside of the computer.
    • Put on the ESD bracelet, making sure the metal circle is touching your skin. Remove the alligator clip from the other end of the bracelet and insert the jack into the ground plug of an active electrical outlet. (the round hole). Do not move forward until you are grounded.
  3. Using the Phillips #1 screwdriver, unscrew the 6.5 mm screw. Using the Phillips #1 screwdriver, unscrew the 6.5 mm screw.
    • Using the Phillips #1 screwdriver, unscrew the 6.5 mm screw.
  4. Grab and slide out the optical drive to remove.
    • Grab and slide out the optical drive to remove.
Abschluss
Ramon Ogaz
104 Reputation
1 Anleitung geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 3
Letzten 30 Tage: 18
Insgesamt: 644
