Zum Hauptinhalt wechseln
Sony Vaio VPCEG26FX Back Panel Replacement
Was du brauchst
  1. Sony Vaio VPCEG26FX Back Panel Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop so the bottom is facing up with the model number visible.
  2. Sony Vaio VPCEG26FX Back Panel Replacement: Schritt 2, Bild 1 von 2 Sony Vaio VPCEG26FX Back Panel Replacement: Schritt 2, Bild 2 von 2
    • Slide the lock switch down until you hear a click to unlock the battery.
  3. Sony Vaio VPCEG26FX Back Panel Replacement: Schritt 3, Bild 1 von 2 Sony Vaio VPCEG26FX Back Panel Replacement: Schritt 3, Bild 2 von 2
    • Slide the release slider up and simultaneously push the battery upwards away from the device until it falls out of place.
  4. Sony Vaio VPCEG26FX Back Panel Replacement: Schritt 4, Bild 1 von 2 Sony Vaio VPCEG26FX Back Panel Replacement: Schritt 4, Bild 2 von 2
    • Remove the battery from the battery compartment.
  5. Sony Vaio VPCEG26FX Back Panel Replacement, Hard Drive: Schritt 5, Bild 1 von 1
    • Loosen the two (7mm) screws that hold the hard drive panel in place with a JIS #0 screwdriver.
    • These screws cannot be removed.
  6. Sony Vaio VPCEG26FX Back Panel Replacement: Schritt 6, Bild 1 von 1
    • Remove the plastic and unscrew the screw on the hard drive using the JIS #0 screwdriver.
  7. Sony Vaio VPCEG26FX Back Panel Replacement: Schritt 7, Bild 1 von 1
    • Push the hard drive towards the optical reader to unlock it.
  8. Sony Vaio VPCEG26FX Back Panel Replacement: Schritt 8, Bild 1 von 1
    • Remove the hard drive from the device.
  9. Sony Vaio VPCEG26FX Back Panel Replacement, RAM: Schritt 9, Bild 1 von 1
    • After you remove the battery, there is a small rectangular panel underneath where the battery was housed.
  10. Sony Vaio VPCEG26FX Back Panel Replacement: Schritt 10, Bild 1 von 1
    • Remove the single screw holding the panel in place using the JIS #0 screwdriver.
  11. Sony Vaio VPCEG26FX Back Panel Replacement: Schritt 11, Bild 1 von 3 Sony Vaio VPCEG26FX Back Panel Replacement: Schritt 11, Bild 2 von 3 Sony Vaio VPCEG26FX Back Panel Replacement: Schritt 11, Bild 3 von 3
    • Remove the green circuit board by dislodging the circuit it is attached to.
    • Unhook it and remove it from the device.
  12. Sony Vaio VPCEG26FX Back Panel Replacement, Back Panel: Schritt 12, Bild 1 von 1
    • Remove the remaining eleven 7mm screws from back panel using the JIS #0 screwdriver.
  13. Sony Vaio VPCEG26FX Back Panel Replacement: Schritt 13, Bild 1 von 2 Sony Vaio VPCEG26FX Back Panel Replacement: Schritt 13, Bild 2 von 2
    • Remove the back panel from the device.
Abschluss
Sara Alfaro
531 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S1-G4, Botvin Spring 2019 Mitglied von UMass Dartmouth, Team S1-G4, Botvin Spring 2019
UMASSD-BOTVIN-S19S1G4
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 891
