Was du brauchst
While holding the release slide, use your thumb to lift the lip of the battery to pull it out.
Use your fingers to pry the cover upward.
Unscrew the two 7mm screws.
Pull the plastic tab in the direction of the arrow to take out.
Remove the 3mm screws with the Phillips #1 Screwdriver from hard drive bracket.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
