Was du brauchst
While holding the release slide, use your thumb to lift the lip of the battery to pull it out.
Within the DVD drive compartment, press on the hole to push the keyboard out of its placement.
The keyboard may need to be loosened on its edges with a plastic spudger.
Using a spudger, or your finger tips, carefully slide the the ribbon keeper open.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
