Zum Hauptinhalt wechseln
Sony Vaio VGN-NW240F (PCG-7184L) Optical Drive Replacement
Was du brauchst
  1. Sony Vaio VGN-NW240F (PCG-7184L) Optical Drive Replacement, Optical Drive: Schritt 1, Bild 1 von 1
    • Locate and unscrew the two highlighted 8 mm Phillips #1 screws.
    • There will be three dots next to the desired screws
  2. Sony Vaio VGN-NW240F (PCG-7184L) Optical Drive Replacement: Schritt 2, Bild 1 von 1
    • Grip the cover of the optical drive and slide it out.
    • If it does not come out, do not force it. Double check to make sure the screws are entirely removed.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 9-17, Regan Spring 2014 Mitglied von Cal Poly, Team 9-17, Regan Spring 2014
CPSU-REGAN-S14S9G17
4 Mitglieder
18 Anleitungen geschrieben
Ein Kommentar
Has anyone found a suitable optical enclosure that would accommodate the front edge of this drive? Every enclosure I've seen so far would have the door protruding past the enclosure's opening (as opposed to sitting flush with the enclosure's opening), leaving its top edge unprotected.
Lotus Flower - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 1,751
