Einleitung
If the motherboard malfunctions, it may need to be replaced, however, such a situation is relatively rare. Please check for other issues before determining if the motherboard is faulty.
Was du brauchst
Power off the laptop.
Unplug the charging cable and any other cables plugged into the laptop.
Turn the laptop over so that the back panel is facing upwards.
Locate two switches above the battery that lock it into place.
Push the left-hand switch, that says "lock" above it, so that it is unlocked.
Push and hold the right-hand switch, which says "release" above it, and lift the battery up out of its place.
Remove all the 8mm Phillips #1 screws on the backside of the laptop.
There are three 3mm and two 5.3mm screws under the battery that also need to be taken out.
There are three 3mm screws under the optical drives that also need to be taken out.
Remove the RAM panel in addition to the other screws. For further instructions, refer to the RAM replacement guide.
Locate and remove three 5.3 mm Phillips #1 screws on the bottom of the fan.
Locate and remove the four 5.3 mm Phillips #1 screws on the top of the fan.
Locate and remove the four 3mm Phillips #1 screws above the processor and attached to the bronze heat-pipes.
Gently lift up the fan and heatsink from the the laptop.
The fan attached onto the heat sink with electrical tape. Removing the electrical tape allows you to replace the fan.
Locate the two highlighted circular openings and push the keyboard out.
Detach the ribbon cable to separate the keyboard from the laptop.
Push open the brown clamp at the base of the ribbon to release it.
Remove the highlighted ribbon cables from their place underneath the keyboard. To do so, lift up on the black clamps to release the cables.
Remove the highlighted 3mm Phillips #1 screws.
Remove the two 8mm Phillips #1 screws that are highlighted.
Detach all of the highlighted connectors.
Detach the black and grey network card cables.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
