Zum Hauptinhalt wechseln
Sony Vaio VPCEL17FX Disc Drive Replacement
Was du brauchst
  1. Sony Vaio VPCEL17FX Disc Drive Replacement, Disc Drive: Schritt 1, Bild 1 von 1
    • Unscrew the screw in the hole marked by three vertical dots, shown here.
    • The screw is located on the bottom panel of the computer, next to the information panel with the production date.
  2. Sony Vaio VPCEL17FX Disc Drive Replacement: Schritt 2, Bild 1 von 1
    • Pull out the 0.6 mm screw, or rotate the laptop and let it fall out.
    • Be sure to not lose track of this screw, it holds the disc drive in place.
  3. Sony Vaio VPCEL17FX Disc Drive Replacement: Schritt 3, Bild 1 von 1
    • Gently pull the edge of the disc drive until you feel it start to come out. Pull it all the way out, and set it aside.
Abschluss
Nick Sanchez
97 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 432
