Zum Hauptinhalt wechseln
Sony Vaio VPCF115FM Back Panel Assembly Replacement
Was du brauchst
  1. Sony Vaio VPCF115FM Back Panel Assembly Replacement, Battery: Schritt 1, Bild 1 von 2 Sony Vaio VPCF115FM Back Panel Assembly Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the laptop over so the bottom is facing up.
  2. Sony Vaio VPCF115FM Back Panel Assembly Replacement: Schritt 2, Bild 1 von 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: Schritt 2, Bild 2 von 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: Schritt 2, Bild 3 von 3
    • Unlock the left tab on the battery.
    • Glide the right battery tab to release the battery pack from the laptop.
    • Keeping the battery tab in the released position, lift the battery up.
  3. Sony Vaio VPCF115FM Back Panel Assembly Replacement, RAM: Schritt 3, Bild 1 von 2 Sony Vaio VPCF115FM Back Panel Assembly Replacement, RAM: Schritt 3, Bild 2 von 2
    • Remove the 9mm Phillips #1 screw located on the back cover.
    • Remove cover.
    • Push out metal tabs.
    • Remove card.
  4. Sony Vaio VPCF115FM Back Panel Assembly Replacement, Hard Drive: Schritt 4, Bild 1 von 1
    • Remove two 9mm Phillips #1 screws.
  5. Sony Vaio VPCF115FM Back Panel Assembly Replacement: Schritt 5, Bild 1 von 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: Schritt 5, Bild 2 von 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: Schritt 5, Bild 3 von 3
    • Remove the panel.
    • Gently remove the hard drive.
    • Remove screws securing caddy to hard drive.
  6. Sony Vaio VPCF115FM Back Panel Assembly Replacement, Disk Drive: Schritt 6, Bild 1 von 2 Sony Vaio VPCF115FM Back Panel Assembly Replacement, Disk Drive: Schritt 6, Bild 2 von 2
    • Remove the 9mm Phillips #1 screw holding the disk drive in place.
    • Remove the 9mm screw near the memory stick.
  7. Sony Vaio VPCF115FM Back Panel Assembly Replacement: Schritt 7, Bild 1 von 1
    • Using an iFixit opening tool, carefully pry the disk drive away from the device.
  8. Sony Vaio VPCF115FM Back Panel Assembly Replacement, Back Panel Assembly: Schritt 8, Bild 1 von 2 Sony Vaio VPCF115FM Back Panel Assembly Replacement, Back Panel Assembly: Schritt 8, Bild 2 von 2
    • Remove three 3mm Phillips #1 screws on the side panel.
  9. Sony Vaio VPCF115FM Back Panel Assembly Replacement: Schritt 9, Bild 1 von 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: Schritt 9, Bild 2 von 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: Schritt 9, Bild 3 von 3
    • On the top of the panel, remove four 3mm Phillips #1 screws.
  10. Sony Vaio VPCF115FM Back Panel Assembly Replacement: Schritt 10, Bild 1 von 1
    • Remove the rest of the twelve 9mm Phillips #1 screws on the back panel.
    • Remove the final screw.
  11. Sony Vaio VPCF115FM Back Panel Assembly Replacement: Schritt 11, Bild 1 von 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: Schritt 11, Bild 2 von 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: Schritt 11, Bild 3 von 3
    • Using an iFixit opening tool, pry the back panel off.
    • At this point, the back panel should very easily pop off.
    • Be careful around mechanical components on the edges of the laptop (audio output, USB ports).
  12. Sony Vaio VPCF115FM Back Panel Assembly Replacement: Schritt 12, Bild 1 von 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: Schritt 12, Bild 2 von 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: Schritt 12, Bild 3 von 3
    • Continue popping the back panel off.
    • The back panel should now be off.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Haylie Hotte
638 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S6-G6, Peak Spring 2019 Mitglied von UMass Dartmouth, Team S6-G6, Peak Spring 2019
UMASSD-PEAK-S19S6G6
3 Mitglieder
10 Anleitungen geschrieben
2 Kommentare
The fan ran at high speed and the laptop would randomly shut down. I suspected a cooling problem. Turned out there was a layer of dust caked on the “fan side” of the cooling fins. I removed the fan/heat sink assembly and used a vacuum and an artist’s brush to clean the fins and fan blades. Put a fresh layer of thermal compound on the CPU and GPU heat sinks and reassembled everything. This back panel removal/replacement instruction page was a great help. Everything went back together successfully and, to my amazement, there were no screws left over!
Wil Higdon - Antwort
Ganhei um Sony Vaio PCG-81114L usado porem nao tem os parafusos (todos) e nao estou encontrado aqui no Brasil. Tem como ajudar? O procedimento esta 10 e é bem simples. My email: joaocastelor@hotmail.com
joaocastelor - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 1,713
