Zum Hauptinhalt wechseln
Sony Vaio PCG-981L Floppy Drive Replacement
Was du brauchst
  1. Sony Vaio PCG-981L Floppy Drive Replacement, Floppy Drive: Schritt 1, Bild 1 von 1
    • Turn the device over so that its underside is facing up. Then, slide the blue floppy drive release button down and pull the floppy drive out of the laptop.
  2. Sony Vaio PCG-981L Floppy Drive Replacement: Schritt 2, Bild 1 von 1
    • Remove the floppy drive from the laptop.
  3. Sony Vaio PCG-981L Floppy Drive Replacement: Schritt 3, Bild 1 von 1
    • There are two screws on each side of the floppy drive (four screws total). Remove these screws.
  4. Sony Vaio PCG-981L Floppy Drive Replacement: Schritt 4, Bild 1 von 1
    • Remove the floppy drive core from its casing.
  5. Sony Vaio PCG-981L Floppy Drive Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the five screws from the back of the optical drive.
  6. Sony Vaio PCG-981L Floppy Drive Replacement: Schritt 6, Bild 1 von 1
    • Remove the two screws holding part of the floppy processing unit.
  7. Sony Vaio PCG-981L Floppy Drive Replacement: Schritt 7, Bild 1 von 1
    • Remove the entire floppy drive processing unit.
  8. Sony Vaio PCG-981L Floppy Drive Replacement: Schritt 8, Bild 1 von 1
    • Here is an isolated image of the core hardware of the floppy drive. This is where the floppy "magic" happens. Check for any connection failures or shortages. You may need to resolder some of the connections.
  9. Sony Vaio PCG-981L Floppy Drive Replacement: Schritt 9, Bild 1 von 1
    • Here is an isolated image of the floppy drive casing unit.
Abschluss
Loratious
10 Reputation
1 Anleitung geschrieben
Cal Poly, Team 18-68, Johann Spring 2010 Mitglied von Cal Poly, Team 18-68, Johann Spring 2010
CPSU-JOHANN-S10S18G68
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 5
Letzte 30 Tage: 6
Insgesamt: 2,751
