Einleitung
This guide shows how to remove the screen of a Sony Vaio SVE111B11L. This repair may be needed if the screen melts or cracks. To replace the screen follow the guide in reverse order.
Was du brauchst
Locate the battery on the bottom of the computer.
Flip the computer so that the battery faces you.
Remove the memory door on the bottom of the computer to access the screw for the keyboard.
Slide the wires out, away from the solder connections.
Flip the computer over and open it.
Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
Using an opening tool, gently pull out and slightly up on the connector clip.
Gently lift the keyboard assembly up and out.
Locate and remove the screws holding the motherboard down.
Screws: L 4.6mm X D 1.85mm
Locate screws. L 3.35mm X D 1.8mm
Remove Screws.
Lay the screen on a hard flat surface.
Remove hinges and wires for ease of removal.
Gently remove the screen cover.
Be careful of the camera at the top of the screen.
Be careful of the seal tape between the cover and the screen.
Locate the wires and connectors.
Unplug the wires from the connectors.
Be careful of the yellow tape around the connection.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
