Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector. Locate the battery on the bottom of the computer.
    • Remove charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector.
    • Locate the battery on the bottom of the computer.
    • Flip Computer Toward Yourself
  2. Locate two latches with the words “lock” and “release” on them. You will use these in the next step.
    • Locate two latches with the words “lock” and “release” on them. You will use these in the next step.
  3. Push the latches towards each other while simultaneously lifting up the battery.
    • Push the latches towards each other while simultaneously lifting up the battery.
  4. iPhone LCD Display Fix Kits
    Die Budgetoption, abgedeckt durch unsere lebenslange Garantie.
    Kits kaufen
    Reduziere die Reparaturkosten, nicht die Qualität.
    Kits kaufen
  5. Remove charging adaptor. Some charge may still be in the battery or computer.
    • DO NOT touch connectors or copper yellow connector.
    • Remove the memory door on the bottom of the computer to access the screw for the keyboard.
    • The screws for the memory door do not come out. they are held from falling out.
  6. Locate the screw that holds the keyboard assembly in place.
    • Locate the screw that holds the keyboard assembly in place.
    • Remove this screw.
    • Size: L 6.7mm X D 1.9mm
  7. Be careful of the keyboard wire connection.
    • Be careful of the keyboard wire connection.
    • Slide the wires out. Make sure to slide away from the solder connections.
    • Flip computer over and open.
  8. Gently pry the keyboard assembly from the front. (closest to the screen) With the blue spudger. Pry until the keyboard is about two inches up. Pull out and up slightly on the connector clip carefully. (Use the  blue spudger)
    • Gently pry the keyboard assembly from the front. (closest to the screen) With the blue spudger.
    • Pry until the keyboard is about two inches up.
    • Pull out and up slightly on the connector clip carefully. (Use the blue spudger)
    • Gently lift the key board assembly up and out.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
John Noll
768 Reputation
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 12
Insgesamt: 736
