Zum Hauptinhalt wechseln
Sony Vaio SVE111B11L Motherboard Replacement
Was du brauchst
  1. Sony Vaio SVE111B11L Motherboard Replacement, Battery: Schritt 1, Bild 1 von 2 Sony Vaio SVE111B11L Motherboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector.
    • Locate the battery on the bottom of the computer.
    • Flip the computer so that the battery faces you.
  2. Sony Vaio SVE111B11L Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Locate the two latches with the words “lock” and “release” on them.
  3. Sony Vaio SVE111B11L Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Push the latches towards each other and lift the battery to remove it.
  4. Sony Vaio SVE111B11L Motherboard Replacement, Keyboard Assembly: Schritt 4, Bild 1 von 1
    • Remove the memory door on the bottom of the computer to access the screw for the keyboard.
    • The screws for the memory door do not come out.
  5. Sony Vaio SVE111B11L Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the 6.7 mm screw that holds the keyboard assembly in place.
  6. Sony Vaio SVE111B11L Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Be careful not to break the keyboard wire connection.
    • Slide the wires out, away from the solder connections.
    • Flip the computer over and open it.
  7. Sony Vaio SVE111B11L Motherboard Replacement: Schritt 7, Bild 1 von 3 Sony Vaio SVE111B11L Motherboard Replacement: Schritt 7, Bild 2 von 3 Sony Vaio SVE111B11L Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
    • Using an opening tool, gently pull out and slightly up on the connector clip.
    • Gently lift the keyboard assembly up and out.
  8. Sony Vaio SVE111B11L Motherboard Replacement, Fan: Schritt 8, Bild 1 von 1
    • Locate the fan and heat-sink.
  9. Sony Vaio SVE111B11L Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Locate the wires and connectors, and gently unplug them.
  10. Sony Vaio SVE111B11L Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Locate and remove the 6.7 mm screws that hold the fan assembly.
  11. Sony Vaio SVE111B11L Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Gently lift the fan assembly up and out.
  12. Sony Vaio SVE111B11L Motherboard Replacement, Motherboard: Schritt 12, Bild 1 von 1
    • Remove charging adaptor. Some charge may still be in the battery or computer.
    • DO NOT touch connectors or copper yellow connector.
    • Take the covers on the bottom of the laptop off.
  13. Sony Vaio SVE111B11L Motherboard Replacement: Schritt 13, Bild 1 von 1
    • Locate and remove the screws holding the motherboard down.
    • Screws: L 4.6mm X D 1.85mm
  14. Sony Vaio SVE111B11L Motherboard Replacement: Schritt 14, Bild 1 von 3 Sony Vaio SVE111B11L Motherboard Replacement: Schritt 14, Bild 2 von 3 Sony Vaio SVE111B11L Motherboard Replacement: Schritt 14, Bild 3 von 3
    • Locate the wires and connectors and remove them from the motherboard.
  15. Sony Vaio SVE111B11L Motherboard Replacement: Schritt 15, Bild 1 von 2 Sony Vaio SVE111B11L Motherboard Replacement: Schritt 15, Bild 2 von 2
    • Lift the mother board out and safely put it to the side.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
John Noll
819 Reputation
5 Anleitungen geschrieben
Ein Kommentar
i have the same laptop, and i mistakenly remove the mother board cmos battery , and is not recognizing my laptop system hard drive.
in this case what can i do in other to restore it back.
onyebuchiadieze - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 14
Letzte 30 Tage: 21
Insgesamt: 1,933
