Einleitung
Use this guide involving the Sony Valo SVE111B11L to replace its motherboard. The motherboard is the main connection point for the whole computer. It is recommended to use the two tools provided by iFixit: the Phillips #0 screwdriver and the iFixit opening tool.
Was du brauchst
Locate the battery on the bottom of the computer.
Flip the computer so that the battery faces you.
Remove the memory door on the bottom of the computer to access the screw for the keyboard.
Slide the wires out, away from the solder connections.
Flip the computer over and open it.
Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
Using an opening tool, gently pull out and slightly up on the connector clip.
Gently lift the keyboard assembly up and out.
Locate and remove the screws holding the motherboard down.
Screws: L 4.6mm X D 1.85mm
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
i have the same laptop, and i mistakenly remove the mother board cmos battery , and is not recognizing my laptop system hard drive.
in this case what can i do in other to restore it back.
