Zum Hauptinhalt wechseln
Sony Vaio SVE15112FXS Hard Drive Replacement
Was du brauchst
  1. Sony Vaio SVE15112FXS Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Power laptop off before beginning.
    • Turn the laptop over so that it is positioned top down with the model number facing you.
  2. Sony Vaio SVE15112FXS Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws securing the hard drive cover.
    • To avoid losing any parts, we recommend that you place the loose screws on a magnetic project mat.
  3. Sony Vaio SVE15112FXS Hard Drive Replacement: Schritt 3, Bild 1 von 2 Sony Vaio SVE15112FXS Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • To expose the hard drive, remove the cover by sliding it toward you and pulling up on the panel.
  4. Sony Vaio SVE15112FXS Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws attaching the hard drive to the laptop.
  5. Sony Vaio SVE15112FXS Hard Drive Replacement: Schritt 5, Bild 1 von 2 Sony Vaio SVE15112FXS Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Pull the clear plastic ribbon to the left until the mount is detached from the laptop.
    • There will be some resistance as the hard drive is disconnected. If it does not move at all, check that all anchor screws are removed.
    • Lift the hard drive out of the well.
  6. Sony Vaio SVE15112FXS Hard Drive Replacement: Schritt 6, Bild 1 von 2 Sony Vaio SVE15112FXS Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Use a #0 Phillips screwdriver to remove the four 4.0 mm screws attaching the mount to the hard drive.
    • Slide the hard drive away from the mount until it is completely detached.
    • Take note of how the mount is positioned when attached to the hard drive.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ashley Bierman
1.223 Reputation
5 Anleitungen geschrieben
Ohio State, Team S1-G1, Whitney Fall 2018 Mitglied von Ohio State, Team S1-G1, Whitney Fall 2018
OSU-WHITNEY-F18S1G1
2 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 698
