Einleitung
The speakers allow the laptop to play sounds such as music. This guide shows the steps to remove the speakers for repair or replacement.
Was du brauchst
Standing so that the barcode and warning labels are upright and legible, push the left tab up and away from yourself.
Standing so that the barcode and warning labels are upright and legible, push the right tab up and away from yourself.
Locate the small gap where the battery and the laptop shell meet. Lift from the gap and rotate the battery up and away from yourself.
Remove 2 bottom screws in the top right on the HDD cover, with a size P000 screwdriver.
Follow wire down its wire channel and remove it from the channel.
Pull up on the connector to disconnect the speakers to the motherboard.
Eine weitere Person hat diese Anleitung absolviert.
