Zum Hauptinhalt wechseln
Sony Vaio SVE151G11L Webcam Replacement
Was du brauchst
  1. Sony Vaio SVE151G11L Webcam Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop over so its underside is facing upwards and visible.
  2. Sony Vaio SVE151G11L Webcam Replacement: Schritt 2, Bild 1 von 1
    • Standing so that the barcode and warning labels are upright and legible, push the left tab up and away from yourself.
  3. Sony Vaio SVE151G11L Webcam Replacement: Schritt 3, Bild 1 von 1
    • Standing so that the barcode and warning labels are upright and legible, push the right tab up and away from yourself.
  4. Sony Vaio SVE151G11L Webcam Replacement: Schritt 4, Bild 1 von 1
    • Locate the small gap where the battery and the laptop shell meet. Lift from the gap and rotate the battery up and away from yourself.
  5. Sony Vaio SVE151G11L Webcam Replacement: Schritt 5, Bild 1 von 1
    • Pull battery away from laptop.
  6. Sony Vaio SVE151G11L Webcam Replacement, Display: Schritt 6, Bild 1 von 1
    • Flip laptop over so the bottom is facing upwards.
    • Remove bottom of laptop.
  7. Sony Vaio SVE151G11L Webcam Replacement: Schritt 7, Bild 1 von 1
    • Remove antenna wires attached to the WiFi card using a plastic opening tool.
  8. Sony Vaio SVE151G11L Webcam Replacement: Schritt 8, Bild 1 von 1
    • Remove the other antenna wire.
  9. Sony Vaio SVE151G11L Webcam Replacement: Schritt 9, Bild 1 von 1
    • Remove the display cable by pulling upwards.
  10. Sony Vaio SVE151G11L Webcam Replacement: Schritt 10, Bild 1 von 1
    • Remove the power display cable with a plastic opening tool by pushing outwards.
  11. Sony Vaio SVE151G11L Webcam Replacement: Schritt 11, Bild 1 von 2 Sony Vaio SVE151G11L Webcam Replacement: Schritt 11, Bild 2 von 2
    • Remove 4 hinge screws with a Phillips #0 screwdriver.
  12. Sony Vaio SVE151G11L Webcam Replacement: Schritt 12, Bild 1 von 2 Sony Vaio SVE151G11L Webcam Replacement: Schritt 12, Bild 2 von 2
    • Lift upward on the hinges with a plastic opening tool to release them.
  13. Sony Vaio SVE151G11L Webcam Replacement: Schritt 13, Bild 1 von 1
    • Separate the bottom of the laptop from the monitor.
  14. Sony Vaio SVE151G11L Webcam Replacement: Schritt 14, Bild 1 von 1
    • Completely detach screen from the laptop.
  15. Sony Vaio SVE151G11L Webcam Replacement, Webcam: Schritt 15, Bild 1 von 1
    • Remove the rubber nipples to expose the screws using the pointed side of the spudger.
  16. Sony Vaio SVE151G11L Webcam Replacement: Schritt 16, Bild 1 von 1
    • Remove each of the screws revealed from the step below with a P00 screwdriver.
  17. Sony Vaio SVE151G11L Webcam Replacement: Schritt 17, Bild 1 von 2 Sony Vaio SVE151G11L Webcam Replacement: Schritt 17, Bild 2 von 2
    • Pop open display housing and follow the plastic to remove the screen.
  18. Sony Vaio SVE151G11L Webcam Replacement: Schritt 18, Bild 1 von 2 Sony Vaio SVE151G11L Webcam Replacement: Schritt 18, Bild 2 von 2
    • Remove the camera cable with the spudger.
  19. Sony Vaio SVE151G11L Webcam Replacement: Schritt 19, Bild 1 von 1
    • Remove screws on both sides using a P000 screwdriver.
  20. Sony Vaio SVE151G11L Webcam Replacement: Schritt 20, Bild 1 von 1
    • Pop out the board using a spudger.
  21. Sony Vaio SVE151G11L Webcam Replacement: Schritt 21, Bild 1 von 1
    • The board is now removed.
Abschluss
Azka Khanani
313 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S9-G9, Valliere Fall 2018 Mitglied von UMass Dartmouth, Team S9-G9, Valliere Fall 2018
UMASSD-VALLIERE-F18S9G9
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 19
Insgesamt: 1,058
