Einleitung
The battery is responsible for the laptop to power on and off. This guide is a quick and simple way on how to remove or replace the battery of a Sony Vaio SVE171C11L
Was du brauchst
Once you flip the laptop over, make sure the right tab is pushed upwards to unlock it.
Use your left hand to push up the left tab to release the battery.
After the battery is released, locate the small gap where the battery and the shell meet. Then lift the gap up and rotate the battery up and away from yourself.
