Zum Hauptinhalt wechseln
Sony Vaio SVE171C11L Hard Drive Replacement
Was du brauchst
  1. Sony Vaio SVE171C11L Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop over so its underside is facing upwards and visible.
  2. Sony Vaio SVE171C11L Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Once you flip the laptop over, make sure the right tab is pushed upwards to unlock it.
    • Use your left hand to push up the left tab to release the battery.
  3. Sony Vaio SVE171C11L Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • After the battery is released, locate the small gap where the battery and the shell meet. Then lift the gap up and rotate the battery up and away from yourself.
  4. Sony Vaio SVE171C11L Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Pull the battery away.
  5. Sony Vaio SVE171C11L Hard Drive Replacement, Hard Drive: Schritt 5, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the two screws that secure the hard drive cover.
  6. Sony Vaio SVE171C11L Hard Drive Replacement: Schritt 6, Bild 1 von 2 Sony Vaio SVE171C11L Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • After the screw have been removed, pop the hard drive cover open.
  7. Sony Vaio SVE171C11L Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the 3 screws that secure the hard drive.
  8. Sony Vaio SVE171C11L Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • When finished removing the screws, use your fingers to hold the blue ribbon attached from the hard drive to remove it from laptop
Abschluss
Edward Briseno
896 Reputation
6 Anleitungen geschrieben
CSU Los Angeles, Team 6-3, Adachi Fall 2022 Mitglied von CSU Los Angeles, Team 6-3, Adachi Fall 2022
CSULA-ADACHI-F22S6G3
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 19
Insgesamt: 256
