Einleitung
If you do not have enough RAM in your computer to do all your tasks, you can replace it for a better verison. Use this guide to properly and safe make the replacement.
Was du brauchst
Once you flip the laptop over, make sure the right tab is pushed upwards to unlock it.
Use your left hand to push up the left tab to release the battery.
After the battery is released, locate the small gap where the battery and the shell meet. Then lift the gap up and rotate the battery up and away from yourself.
Use both hands to unlock the clips that are securing the RAM.
The RAM will pop out from the slot when release the clip. After unlocking, slide out the RAM from their slots.
When inserting new RAM do not forget the put the clips back on.
