Zum Hauptinhalt wechseln
Sony Vaio SVF15A16CXB Back Panel Replacement
Was du brauchst
  1. Sony Vaio SVF15A16CXB Back Panel  Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • 6 mm screws marked in red, 4 mm marked in orange
  2. Sony Vaio SVF15A16CXB Back Panel  Replacement: Schritt 2, Bild 1 von 2 Sony Vaio SVF15A16CXB Back Panel  Replacement: Schritt 2, Bild 2 von 2
    • Using a plastic opening tool, pull the optical drive out of the computer by the seam.
    • In reassembly, slide the optical drive back in after reapplying cover.
  3. Sony Vaio SVF15A16CXB Back Panel  Replacement: Schritt 3, Bild 1 von 1
    • Run the opening tool along the bottom cover seam.
  4. Sony Vaio SVF15A16CXB Back Panel  Replacement: Schritt 4, Bild 1 von 1
    • Lift the clip marked in red in order to release the back cover.
    • Lift the back cover.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 1,035
