Zum Hauptinhalt wechseln
Sony Vaio SVF15A16CXB Fan Replacement
Was du brauchst
  1. Sony Vaio SVF15A16CXB Fan  Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • 6 mm screws marked in red, 4 mm marked in orange
  2. Sony Vaio SVF15A16CXB Fan  Replacement: Schritt 2, Bild 1 von 2 Sony Vaio SVF15A16CXB Fan  Replacement: Schritt 2, Bild 2 von 2
    • Using a plastic opening tool, pull the optical drive out of the computer by the seam.
    • In reassembly, slide the optical drive back in after reapplying cover.
  3. Sony Vaio SVF15A16CXB Fan  Replacement: Schritt 3, Bild 1 von 1
    • Run the opening tool along the bottom cover seam.
  4. Sony Vaio SVF15A16CXB Fan  Replacement: Schritt 4, Bild 1 von 1
    • Lift the clip marked in red in order to release the back cover.
    • Lift the back cover.
  5. Sony Vaio SVF15A16CXB Fan  Replacement, Fan: Schritt 5, Bild 1 von 1
    • Unplug the clip (red black yellow wires) by pulling it in an upward direction.
  6. Sony Vaio SVF15A16CXB Fan  Replacement: Schritt 6, Bild 1 von 1
    • Remove two 4mm screws on the left side of the circular fan.
    • Both of these screws have a white washer attached.
  7. Sony Vaio SVF15A16CXB Fan  Replacement: Schritt 7, Bild 1 von 1
    • Unscrew the four 4mm screws from the connecting copper piece. The two screws are located on either side of the copper piece.
    • The 4 mm screws won’t come out but the fan will, the screws are just to hold the fan in place.
  8. Sony Vaio SVF15A16CXB Fan  Replacement: Schritt 8, Bild 1 von 2 Sony Vaio SVF15A16CXB Fan  Replacement: Schritt 8, Bild 2 von 2
    • Gently pull off the fan from the motherboard.
Abschluss
qiuhong Li
109 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 526
