Zum Hauptinhalt wechseln
Sony Vaio SVF15A16CXB RAM Replacement
Was du brauchst
  1. Sony Vaio SVF15A16CXB RAM Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • 6 mm screws marked in red, 4 mm marked in orange
  2. Sony Vaio SVF15A16CXB RAM Replacement: Schritt 2, Bild 1 von 2 Sony Vaio SVF15A16CXB RAM Replacement: Schritt 2, Bild 2 von 2
    • Using a plastic opening tool, pull the optical drive out of the computer by the seam.
    • In reassembly, slide the optical drive back in after reapplying cover.
  3. Sony Vaio SVF15A16CXB RAM Replacement: Schritt 3, Bild 1 von 1
    • Run the opening tool along the bottom cover seam.
  4. Sony Vaio SVF15A16CXB RAM Replacement: Schritt 4, Bild 1 von 1
    • Lift the clip marked in red in order to release the back cover.
    • Lift the back cover.
  5. Sony Vaio SVF15A16CXB RAM Replacement, RAM: Schritt 5, Bild 1 von 1
    • Locate the two metal clips securing the RAM.
  6. Sony Vaio SVF15A16CXB RAM Replacement: Schritt 6, Bild 1 von 1
    • Pull apart the two metal clips with your fingers.
    • Once you pull the metal clips away, the RAM will spring up from its original position.
  7. Sony Vaio SVF15A16CXB RAM Replacement: Schritt 7, Bild 1 von 1
    • Pull the RAM out of the laptop.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 686
