Was du brauchst
Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
Using a plastic opening tool, pull the optical drive out of the computer by the seam.
Lift the clip marked in red in order to release the back cover.
Lift the back cover.
Unscrew the three 4mm screws with the Phillips #0 screwdriver located on the outer edge of the hard drive.
Lift hard drive up from it groundings.
Slide hard drive to the left in order to remove it.
Eine weitere Person hat diese Anleitung absolviert.
