Einleitung
We will be replacing the RAM in a Sony Vaio SVS151190X laptop. If the device is running slow, it may be time for a RAM replacement. If your device is running slow, even with very few programs running you may need a replacement. Installing a higher quality RAM stick will allow the device to handle more programs running at the same time, as well as run high demand games. Before buying a new RAM stick ensure your device’s operating system and drivers are updated. You may not need to buy/install more RAM if the problem can be fixed with some software updates.
Was du brauchst
Using a #1 Phillips screwdriver, remove the two 5mm screws.
Slide off the back cover.
The RAM is secured by two arms. Push the two arms outward with the Opening Picks or any appropriate substitute to release the RAM stick.
Remove the RAM from the device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
