Zum Hauptinhalt wechseln
Sony Vaio SVT151A11L USB Port Board Replacement
Was du brauchst
  1. Sony Vaio SVT151A11L USB Port Board Replacement, Battery: Schritt 1, Bild 1 von 2 Sony Vaio SVT151A11L USB Port Board Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the laptop over so that the battery on the underside of the device is revealed.
    • Unscrew the two 11mm slotted silver screws that can be found at the top of the battery.
  2. Sony Vaio SVT151A11L USB Port Board Replacement: Schritt 2, Bild 1 von 3 Sony Vaio SVT151A11L USB Port Board Replacement: Schritt 2, Bild 2 von 3 Sony Vaio SVT151A11L USB Port Board Replacement: Schritt 2, Bild 3 von 3
    • Wedge the plastic opening tool between the back panel and the battery on the top left side of the device.
    • Push down on the plastic opening tool until the battery lifts from the back of the laptop.
    • Grab the battery and remove it from the device.
  3. Sony Vaio SVT151A11L USB Port Board Replacement, Back Panel: Schritt 3, Bild 1 von 3 Sony Vaio SVT151A11L USB Port Board Replacement, Back Panel: Schritt 3, Bild 2 von 3 Sony Vaio SVT151A11L USB Port Board Replacement, Back Panel: Schritt 3, Bild 3 von 3
    • Unscrew the three 4mm screws using a JIS #0 screwdriver.
    • Unscrew the eight 7 mm screws using a JIS #0 screwdriver.
    • Grab and lift the edge of the panel to pull it free from the rest of the computer.
  4. Sony Vaio SVT151A11L USB Port Board Replacement: Schritt 4, Bild 1 von 3 Sony Vaio SVT151A11L USB Port Board Replacement: Schritt 4, Bild 2 von 3 Sony Vaio SVT151A11L USB Port Board Replacement: Schritt 4, Bild 3 von 3
    • Grab the disk drive located at the edge of the computer and pull it it out.
    • Unscrew the three 7 mm screws with a JIS #0 screwdriver.
  5. Sony Vaio SVT151A11L USB Port Board Replacement, USB Port Board: Schritt 5, Bild 1 von 2 Sony Vaio SVT151A11L USB Port Board Replacement, USB Port Board: Schritt 5, Bild 2 von 2
    • Use a JIS #0 screwdriver to unscrew the two 4mm screws from the board.
  6. Sony Vaio SVT151A11L USB Port Board Replacement: Schritt 6, Bild 1 von 3 Sony Vaio SVT151A11L USB Port Board Replacement: Schritt 6, Bild 2 von 3 Sony Vaio SVT151A11L USB Port Board Replacement: Schritt 6, Bild 3 von 3
    • Lift board and peel the ribbon cable from the computer.
    • Lift and pull the end of the ribbon cable to remove it from the slot.
Abschluss
UMass Dartmouth, Team S4-G6, Julie Fall 2017 Mitglied von UMass Dartmouth, Team S4-G6, Julie Fall 2017
UMASSD-JULIE-F17S4G6
2 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 1,052
