Zum Hauptinhalt wechseln
Sony Vaio Tap 11 Battery Replacement
Was du brauchst
  1. Sony Vaio Tap 11 Battery Replacement, Screen Assembly: Schritt 1, Bild 1 von 1
    • Begin by opening the HDMI/USB port cover on the left edge.
    • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
  2. Sony Vaio Tap 11 Battery Replacement: Schritt 2, Bild 1 von 1
    • Locate and open the Micro SD slot on the top side of the device.
    • Remove the two screws located beneath the cover.
  3. Sony Vaio Tap 11 Battery Replacement: Schritt 3, Bild 1 von 2 Sony Vaio Tap 11 Battery Replacement: Schritt 3, Bild 2 von 2
    • Attach the suction cup to the top right area of the screen.
    • Pull to separate the screen from the rest of the device.
    • Be aware of the front camera cable that is still connected to the rest of the device.
    • Detach the display ribbon cable.
  4. Sony Vaio Tap 11 Battery Replacement, Battery: Schritt 4, Bild 1 von 1
    • Disconnect the battery from the motherboard by pulling out the cable below the fan.
  5. Sony Vaio Tap 11 Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the seven 3 mm Phillips #000 screws that hold the battery in place.
    • Carefully remove the battery from the back assembly.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
IUPUI, Team 1-2, Harley Fall 2015 Mitglied von IUPUI, Team 1-2, Harley Fall 2015
IUPUI-HARLEY-F15S1G2
4 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 19
Insgesamt: 6,064
