Einleitung
The power plug is one of the most important parts of a laptop or tablet device. Without it, charging the internal battery is impossible!
Was du brauchst
Begin by opening the HDMI/USB port cover on the left edge.
Remove the three #000 headed, 3 mm long screws located underneath the port cover.
Locate and open the Micro SD slot on the top side of the device.
Remove the two screws located beneath the cover.
Attach the suction cup to the top right area of the screen.
Pull to separate the screen from the rest of the device.
Detach the display ribbon cable.
Disconnect the battery from the motherboard by pulling out the cable below the fan.
Remove the seven 3 mm Phillips #000 screws that hold the battery in place.
Carefully remove the battery from the back assembly.
Remove the two 3mm Phillips #000 screws from the bottom left corner of the device.
3 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
I wonder if you have the part number or can supply this power jack?
Yes, Where can I find this replacement part?
