Einleitung
In this guide, you will remove the 5 screws holding the device together. In addition, this guide details the various cables connecting the screen to the motherboard.
Was du brauchst
Begin by opening the HDMI/USB port cover on the left edge.
Remove the three #000 headed, 3 mm long screws located underneath the port cover.
Locate and open the Micro SD slot on the top side of the device.
Remove the two screws located beneath the cover.
Attach the suction cup to the top right area of the screen.
Pull to separate the screen from the rest of the device.
Detach the display ribbon cable.
3 weitere Personen haben diese Anleitung absolviert.
