Zum Hauptinhalt wechseln
Sony Vaio Tap 11 Screen Camera Module Replacement Replacement
Was du brauchst
  1. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement, Screen Assembly: Schritt 1, Bild 1 von 1
    • Begin by opening the HDMI/USB port cover on the left edge.
    • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
  2. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: Schritt 2, Bild 1 von 1
    • Locate and open the Micro SD slot on the top side of the device.
    • Remove the two screws located beneath the cover.
  3. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: Schritt 3, Bild 1 von 2 Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: Schritt 3, Bild 2 von 2
    • Attach the suction cup to the top right area of the screen.
    • Pull to separate the screen from the rest of the device.
    • Be aware of the front camera cable that is still connected to the rest of the device.
    • Detach the display ribbon cable.
  4. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement, Screen Camera Module Replacement: Schritt 4, Bild 1 von 1
    • Flip device upward carefully like you are turning the page of a book.
  5. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the camera cable from the device backing.
  6. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: Schritt 6, Bild 1 von 1
    • Remove the single 3 mm Phillips #000 screw on the left side of the module.
    • Remove the module from the front panel assembly.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
IUPUI, Team 1-2, Harley Fall 2015 Mitglied von IUPUI, Team 1-2, Harley Fall 2015
IUPUI-HARLEY-F15S1G2
4 Mitglieder
20 Anleitungen geschrieben
Ein Kommentar
Is it possible to replace the camera module with a different one? I think that it is a usb camera. I would like to replace it a newer sony model.
Matthew Harper - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 893
