Was du brauchst
Begin by opening the HDMI/USB port cover on the left edge.
Remove the three #000 headed, 3 mm long screws located underneath the port cover.
Locate and open the Micro SD slot on the top side of the device.
Remove the two screws located beneath the cover.
Attach the suction cup to the top right area of the screen.
Pull to separate the screen from the rest of the device.
Detach the display ribbon cable.
Pull the SSD towards the right and slightly up, removing it from the back assembly.
Begin by removing the orange ribbon cable connecting the motherboard to the daughterboard, located above the SSD.
Gently tug either side until it releases, then pull out the other end.
2 weitere Personen haben diese Anleitung absolviert.
