Zum Hauptinhalt wechseln
Sony Vaio Tap 21 SVT212A11L Fan Replacement
Was du brauchst
  1. Sony Vaio Tap 21 SVT212A11L Fan Replacement, Screen: Schritt 1, Bild 1 von 2 Sony Vaio Tap 21 SVT212A11L Fan Replacement, Screen: Schritt 1, Bild 2 von 2
    • Insert the plastic opening tool at an angle into the grill and lift the tab by applying force down and to the left as you are lifting it out of place.
    • Use your plastic opening tool to remove the right plastic tab blocking the screw mounts behind the device.
    • The plastic tab is located on a plastic stretch of grill running along the upper half of the back of the device.
    • You can find the tab looking for a solid fill within the grill. The tab is solid within the slits.
  2. Sony Vaio Tap 21 SVT212A11L Fan Replacement: Schritt 2, Bild 1 von 2 Sony Vaio Tap 21 SVT212A11L Fan Replacement: Schritt 2, Bild 2 von 2
  3. Sony Vaio Tap 21 SVT212A11L Fan Replacement: Schritt 3, Bild 1 von 3 Sony Vaio Tap 21 SVT212A11L Fan Replacement: Schritt 3, Bild 2 von 3 Sony Vaio Tap 21 SVT212A11L Fan Replacement: Schritt 3, Bild 3 von 3
    • Remove the two 5mm screws on the back of the device using a JIS 0 screwdriver.
  4. Sony Vaio Tap 21 SVT212A11L Fan Replacement: Schritt 4, Bild 1 von 3 Sony Vaio Tap 21 SVT212A11L Fan Replacement: Schritt 4, Bild 2 von 3 Sony Vaio Tap 21 SVT212A11L Fan Replacement: Schritt 4, Bild 3 von 3
    • Face the screen of the device upwards.
    • Gently un-clip the screen around the four sides of the body with the plastic opening tool.
    • Use an up-down motion.
    • It would be easier to do this if the device is fully rested flat by pushing the device down. It should rest on the stand.
  5. Sony Vaio Tap 21 SVT212A11L Fan Replacement: Schritt 5, Bild 1 von 3 Sony Vaio Tap 21 SVT212A11L Fan Replacement: Schritt 5, Bild 2 von 3 Sony Vaio Tap 21 SVT212A11L Fan Replacement: Schritt 5, Bild 3 von 3
    • Lift the screen gently from the top of the device.
    • Make sure to lift the screen from the same side the screws were removed.
  6. Sony Vaio Tap 21 SVT212A11L Fan Replacement: Schritt 6, Bild 1 von 1
    • Slowly and gently lay the screen on its face.
    • It's important that the cables are not damaged while doing this process. Ensure as you lay the screen on its face any cables are carefully moved insuring no stress is applied on the cables.
  7. Sony Vaio Tap 21 SVT212A11L Fan Replacement, Fan: Schritt 7, Bild 1 von 1
    • Remove four 9mm screws from the fan attachment located on the motherboard with a Phillips #1 screwdriver.
  8. Sony Vaio Tap 21 SVT212A11L Fan Replacement: Schritt 8, Bild 1 von 1
    • Remove two 6mm screws located on both sides of the fan component using a Phillips #1 screwdriver.
  9. Sony Vaio Tap 21 SVT212A11L Fan Replacement: Schritt 9, Bild 1 von 1
    • Un-click the cables attached to the face of the motherboard.
    • These cables are secured tight in their place so remove them with a firm grip.
  10. Sony Vaio Tap 21 SVT212A11L Fan Replacement: Schritt 10, Bild 1 von 2 Sony Vaio Tap 21 SVT212A11L Fan Replacement: Schritt 10, Bild 2 von 2
    • Firmly lift the fan from the surface.
    • The fan is held tight in its place so lift it with slightly more force.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team S4-G4, Livingston Fall 2017 Mitglied von Cal Poly, Team S4-G4, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G4
4 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Very nice guide. Thank you. Have you replaced the CPU yet in this model?
Bill Scharf - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 668
