Zum Hauptinhalt wechseln
Sony Vaio VGN-FS640 Fan Replacement
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. Sony Vaio VGN-FS640 Fan Replacement, Backplate: Schritt 1, Bild 1 von 1
    • Turn off the laptop and disconnect any charging cables.
    • Flip the laptop over so that the Service Tag is shown at the top left corner.
  2. Sony Vaio VGN-FS640 Fan Replacement: Schritt 2, Bild 1 von 1
    • Remove the highlighted screws from the back of the laptop with a Phillips #0 Screwdriver.
  3. Sony Vaio VGN-FS640 Fan Replacement: Schritt 3, Bild 1 von 1
    • Remove the highlighted screws from the panels in the bottom right-hand corner of the laptop using the Phillips #0 Screwdriver.
  4. Sony Vaio VGN-FS640 Fan Replacement: Schritt 4, Bild 1 von 1
    • Remove the two panels in the bottom right-hand corner by sliding in the direction of the arrows imprinted on the panels.
  5. Sony Vaio VGN-FS640 Fan Replacement: Schritt 5, Bild 1 von 1
    • Remove the highlighted screws underneath the removed panels using the Phillips #0 Screwdriver.
  6. Sony Vaio VGN-FS640 Fan Replacement: Schritt 6, Bild 1 von 1
    • Carefully remove the hard drive from the panel in the bottom right-hand corner of the laptop.
  7. Sony Vaio VGN-FS640 Fan Replacement: Schritt 7, Bild 1 von 1
    • Locate the battery, located on the top side of the laptop to the right of the Service Tag .
    • Remove the battery by pressing inwards on the tabs on either side of the battery.
  8. Sony Vaio VGN-FS640 Fan Replacement: Schritt 8, Bild 1 von 1
    • Remove cover in the top left side of the laptop next to the battery by pulling it outwards.
  9. Sony Vaio VGN-FS640 Fan Replacement: Schritt 9, Bild 1 von 1
    • Remove the backplate of the laptop by pulling it away from the laptop.
  10. Sony Vaio VGN-FS640 Fan Replacement, Fan: Schritt 10, Bild 1 von 3 Sony Vaio VGN-FS640 Fan Replacement, Fan: Schritt 10, Bild 2 von 3 Sony Vaio VGN-FS640 Fan Replacement, Fan: Schritt 10, Bild 3 von 3
    • Gently remove the connector for the wire running over the fan by lifting the tab on top up with your fingernail and sliding it out.
  11. Sony Vaio VGN-FS640 Fan Replacement: Schritt 11, Bild 1 von 2 Sony Vaio VGN-FS640 Fan Replacement: Schritt 11, Bild 2 von 2
    • Remove the four screws securing the fan.
  12. Sony Vaio VGN-FS640 Fan Replacement: Schritt 12, Bild 1 von 2 Sony Vaio VGN-FS640 Fan Replacement: Schritt 12, Bild 2 von 2
    • Gently lift out the fan.
    • Do not forcefully pull the fan away. This may damage the circuit board.
  13. Sony Vaio VGN-FS640 Fan Replacement: Schritt 13, Bild 1 von 2 Sony Vaio VGN-FS640 Fan Replacement: Schritt 13, Bild 2 von 2
    • Gently disconnect the remaining wire connecting the fan to the circuit board.
    • Remove the fan from the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Geoffrey
252 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 2-6, Vijaybhaskar Spring 2014 Mitglied von UMass Dartmouth, Team 2-6, Vijaybhaskar Spring 2014
UMASSD-VIJAYBHASKAR-S14S2G6
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 543
