Einleitung
Removing the back panel on the laptop allows access to the inner components.
Was du brauchst
Power off the laptop.
Unplug the charging cable and any other cables plugged into the laptop.
Turn the laptop over so that the back panel is facing upwards.
Locate two switches above the battery that lock it into place.
Push the left-hand switch, that says "lock" above it, so that it is unlocked.
Push and hold the right-hand switch, which says "release" above it, and lift the battery up out of its place.
Remove all the 8mm Phillips #1 screws on the backside of the laptop.
There are three 3mm and two 5.3mm screws under the battery that also need to be taken out.
There are three 3mm screws under the optical drives that also need to be taken out.
Remove the RAM panel in addition to the other screws. For further instructions, refer to the RAM replacement guide.
7 weitere Personen haben diese Anleitung absolviert.
