Zum Hauptinhalt wechseln
Sony Vaio VGN-NW240F (PCG-7184L) Keyboard Replacement
Was du brauchst
  1. Sony Vaio VGN-NW240F (PCG-7184L) Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power off the laptop.
    • Unplug the charging cable and any other cables plugged into the laptop.
    • Failure to remove or unplug any cables could result in electric shock.
    • Turn the laptop over so that the back panel is facing upwards.
  2. Sony Vaio VGN-NW240F (PCG-7184L) Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Locate two switches above the battery that lock it into place.
    • Push the left-hand switch, that says "lock" above it, so that it is unlocked.
  3. Sony Vaio VGN-NW240F (PCG-7184L) Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Push and hold the right-hand switch, which says "release" above it, and lift the battery up out of its place.
  4. Sony Vaio VGN-NW240F (PCG-7184L) Keyboard Replacement, Optical Drive: Schritt 4, Bild 1 von 1
    • Locate and unscrew the two highlighted 8 mm Phillips #1 screws.
    • There will be three dots next to the desired screws
  5. Sony Vaio VGN-NW240F (PCG-7184L) Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Grip the cover of the optical drive and slide it out.
    • If it does not come out, do not force it. Double check to make sure the screws are entirely removed.
  6. Sony Vaio VGN-NW240F (PCG-7184L) Keyboard Replacement, Back Panel: Schritt 6, Bild 1 von 3 Sony Vaio VGN-NW240F (PCG-7184L) Keyboard Replacement, Back Panel: Schritt 6, Bild 2 von 3 Sony Vaio VGN-NW240F (PCG-7184L) Keyboard Replacement, Back Panel: Schritt 6, Bild 3 von 3
    • Remove all the 8mm Phillips #1 screws on the backside of the laptop.
    • There are three 3mm and two 5.3mm screws under the battery that also need to be taken out.
    • There are three 3mm screws under the optical drives that also need to be taken out.
    • Remove the RAM panel in addition to the other screws. For further instructions, refer to the RAM replacement guide.
  7. Sony Vaio VGN-NW240F (PCG-7184L) Keyboard Replacement: Schritt 7, Bild 1 von 3 Sony Vaio VGN-NW240F (PCG-7184L) Keyboard Replacement: Schritt 7, Bild 2 von 3 Sony Vaio VGN-NW240F (PCG-7184L) Keyboard Replacement: Schritt 7, Bild 3 von 3
    • Pry along the edges of the back panel using the spudger.
    • If you are struggling to remove the back panel with a moderate amount of force, do NOT apply any additional force, instead double check to make sure all the screws were removed before attempting again.
  8. Sony Vaio VGN-NW240F (PCG-7184L) Keyboard Replacement, Fan: Schritt 8, Bild 1 von 1
    • Locate and remove three 5.3 mm Phillips #1 screws on the bottom of the fan.
    • Locate and remove the four 5.3 mm Phillips #1 screws on the top of the fan.
  9. Sony Vaio VGN-NW240F (PCG-7184L) Keyboard Replacement: Schritt 9, Bild 1 von 1
    • Locate and remove the four 3mm Phillips #1 screws above the processor and attached to the bronze heat-pipes.
    • Gently lift up the fan and heatsink from the the laptop.
    • If the fan and heatsink will not lift up with ease, do NOT apply any additional force. Check again to see if all necessary screws are removed.
  10. Sony Vaio VGN-NW240F (PCG-7184L) Keyboard Replacement: Schritt 10, Bild 1 von 1
    • The fan attached onto the heat sink with electrical tape. Removing the electrical tape allows you to replace the fan.
  11. Sony Vaio VGN-NW240F (PCG-7184L) Keyboard Replacement, Keyboard: Schritt 11, Bild 1 von 1
    • Locate the two highlighted circular openings and push the keyboard out.
    • There is a ribbon cable attaching the keyboard to the back of the motherboard. Avoid damaging the ribbon when pushing out the keyboard.
  12. Sony Vaio VGN-NW240F (PCG-7184L) Keyboard Replacement: Schritt 12, Bild 1 von 1
    • Detach the ribbon cable to separate the keyboard from the laptop.
    • Push open the brown clamp at the base of the ribbon to release it.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 9-17, Regan Spring 2014 Mitglied von Cal Poly, Team 9-17, Regan Spring 2014
CPSU-REGAN-S14S9G17
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 21
Insgesamt: 7,020
