Zum Hauptinhalt wechseln
Einleitung
How to take out the Sony Vaio VGN-S260 keyboard
Ersatzteile
Keine Ersatzteile angegeben.
  1. Sony Vaio VGN-S260 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 3 Sony Vaio VGN-S260 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 3 Sony Vaio VGN-S260 Keyboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Flip the laptop over so the Vaio logo is facing down.
    • Locate the battery at the top and Find the release and unlock slides on the battery.
    • Slide the unlock tab to the unlock position.
    • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
  2. Sony Vaio VGN-S260 Keyboard Replacement: Schritt 2, Bild 1 von 2 Sony Vaio VGN-S260 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • With the tabs still in the unlock position, slide the battery away from the main case.
  3. Sony Vaio VGN-S260 Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 2 Sony Vaio VGN-S260 Keyboard Replacement, Keyboard: Schritt 3, Bild 2 von 2
    • Flip the computer over so the Vaio logo is facedown.
    • Unscrew the 2 screws next to the battery.
  4. Sony Vaio VGN-S260 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Flip the computer over again so the Vaio logo is face up.
    • Open the lid.
  5. Sony Vaio VGN-S260 Keyboard Replacement: Schritt 5, Bild 1 von 2 Sony Vaio VGN-S260 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Press down on the outer gray shell around the keyboard.
    • Use the spudger to gently lift keyboard.
    • Do not pull up the keyboard too far as it is attached to a ribbon underneath.
  6. Sony Vaio VGN-S260 Keyboard Replacement: Schritt 6, Bild 1 von 2 Sony Vaio VGN-S260 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Lift up lever underneath the ribbon to detach the keyboard.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Jeffrey Bryan
552 Reputation
11 Anleitungen geschrieben
Cal Poly, Team 16-4, Maness Spring 2010 Mitglied von Cal Poly, Team 16-4, Maness Spring 2010
CPSU-MANESS-S10S16G4
4 Mitglieder
19 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 5,371
