Zum Hauptinhalt wechseln
Einleitung
How to take out the Optical Drive from the Sony Vaio VGN-S260 laptop
Ersatzteile
Keine Ersatzteile angegeben.
  1. Sony Vaio VGN-S260 Optical Drive Replacement, Battery: Schritt 1, Bild 1 von 3 Sony Vaio VGN-S260 Optical Drive Replacement, Battery: Schritt 1, Bild 2 von 3 Sony Vaio VGN-S260 Optical Drive Replacement, Battery: Schritt 1, Bild 3 von 3
    • Flip the laptop over so the Vaio logo is facing down.
    • Locate the battery at the top and Find the release and unlock slides on the battery.
    • Slide the unlock tab to the unlock position.
    • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
  2. Sony Vaio VGN-S260 Optical Drive Replacement: Schritt 2, Bild 1 von 2 Sony Vaio VGN-S260 Optical Drive Replacement: Schritt 2, Bild 2 von 2
    • With the tabs still in the unlock position, slide the battery away from the main case.
  3. Sony Vaio VGN-S260 Optical Drive Replacement, Keyboard: Schritt 3, Bild 1 von 2 Sony Vaio VGN-S260 Optical Drive Replacement, Keyboard: Schritt 3, Bild 2 von 2
    • Flip the computer over so the Vaio logo is facedown.
    • Unscrew the 2 screws next to the battery.
  4. Sony Vaio VGN-S260 Optical Drive Replacement: Schritt 4, Bild 1 von 1
    • Flip the computer over again so the Vaio logo is face up.
    • Open the lid.
  5. Sony Vaio VGN-S260 Optical Drive Replacement: Schritt 5, Bild 1 von 2 Sony Vaio VGN-S260 Optical Drive Replacement: Schritt 5, Bild 2 von 2
    • Press down on the outer gray shell around the keyboard.
    • Use the spudger to gently lift keyboard.
    • Do not pull up the keyboard too far as it is attached to a ribbon underneath.
  6. Sony Vaio VGN-S260 Optical Drive Replacement: Schritt 6, Bild 1 von 2 Sony Vaio VGN-S260 Optical Drive Replacement: Schritt 6, Bild 2 von 2
    • Lift up lever underneath the ribbon to detach the keyboard.
  7. Sony Vaio VGN-S260 Optical Drive Replacement, Upper Casing: Schritt 7, Bild 1 von 1
    • Remove memory/wireless compartment cover.
  8. Sony Vaio VGN-S260 Optical Drive Replacement: Schritt 8, Bild 1 von 3 Sony Vaio VGN-S260 Optical Drive Replacement: Schritt 8, Bild 2 von 3 Sony Vaio VGN-S260 Optical Drive Replacement: Schritt 8, Bild 3 von 3
    • Flip so the Vaio Logo is face down.
    • Locate and remove a total of 8 screws on the bottom.
  9. Sony Vaio VGN-S260 Optical Drive Replacement: Schritt 9, Bild 1 von 1
    • Find and remove 5 screws (they all have arrows next to them) from cover.
  10. Sony Vaio VGN-S260 Optical Drive Replacement: Schritt 10, Bild 1 von 3 Sony Vaio VGN-S260 Optical Drive Replacement: Schritt 10, Bild 2 von 3 Sony Vaio VGN-S260 Optical Drive Replacement: Schritt 10, Bild 3 von 3
    • Flip the laptop over so the Vaio logo is face up.
    • Use the spudger to pop up the upper casing.
    • Do not lift too much as the upper casing is attached to wires underneath.
    • Remove the wires that are attaching the upper casing to the motherboard.
  11. Sony Vaio VGN-S260 Optical Drive Replacement: Schritt 11, Bild 1 von 1
    • Remove the upper casing.
  12. Sony Vaio VGN-S260 Optical Drive Replacement, Optical Drive: Schritt 12, Bild 1 von 1
    • Remove the screw holding the optical drive casing to the logic board.
  13. Sony Vaio VGN-S260 Optical Drive Replacement: Schritt 13, Bild 1 von 1
    • Locate ribbon connecting optical drive case to logic board.
    • Pop off the ribbon.
    • Remove the metal PC-Card cage.
  14. Sony Vaio VGN-S260 Optical Drive Replacement: Schritt 14, Bild 1 von 1
    • Remove the four screws holding the optical drive to the logic board.
  15. Sony Vaio VGN-S260 Optical Drive Replacement: Schritt 15, Bild 1 von 2 Sony Vaio VGN-S260 Optical Drive Replacement: Schritt 15, Bild 2 von 2
    • Locate brown locking tab above optical drive.
    • Lift up on brown locking tab until ribbon is loose.
    • Gently slide out and remove the optical drive from the computer.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Jeffrey Bryan
552 Reputation
11 Anleitungen geschrieben
Cal Poly, Team 16-4, Maness Spring 2010 Mitglied von Cal Poly, Team 16-4, Maness Spring 2010
CPSU-MANESS-S10S16G4
4 Mitglieder
19 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 6
Insgesamt: 4,425
