Zum Hauptinhalt wechseln
Sony Vaio VGN-SR140E CD/DVD Drive Replacement
Was du brauchst
  1. Sony Vaio VGN-SR140E CD/DVD Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: Schritt 2, Bild 1 von 1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: Schritt 3, Bild 1 von 2 Sony Vaio VGN-SR140E CD/DVD Drive Replacement: Schritt 3, Bild 2 von 2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E CD/DVD Drive Replacement, CD/DVD Drive: Schritt 4, Bild 1 von 1
    • Use a Phillips #1 screwdriver to loosen all four screws. These screws are secured to their covers with retaining clips.
  5. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: Schritt 5, Bild 1 von 1
    • Lift the two covers with a fingernail or plastic opening tool from the sides the screws were present. Two tabs are securing the covers on the side opposite the screws.
  6. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: Schritt 6, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove both 6.5mm screws and set them aside.
  7. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: Schritt 7, Bild 1 von 1
    • Gently slide the CD/DVD drive out of the laptop.
Abschluss
Jeremy
722 Reputation
4 Anleitungen geschrieben
Michigan Tech, Team 1-6, Lauer Spring 2015 Mitglied von Michigan Tech, Team 1-6, Lauer Spring 2015
MTU-LAUER-S15S1G6
2 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 965
