Zum Hauptinhalt wechseln
Sony Vaio VGN-SR140E RAM Replacement
Was du brauchst
  1. Sony Vaio VGN-SR140E RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E RAM Replacement: Schritt 2, Bild 1 von 1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E RAM Replacement: Schritt 3, Bild 1 von 2 Sony Vaio VGN-SR140E RAM Replacement: Schritt 3, Bild 2 von 2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E RAM Replacement, RAM: Schritt 4, Bild 1 von 1
    • Using a Phillips #1 screwdriver, remove both screws. The screws are secured to the cover with retaining clips.
  5. Sony Vaio VGN-SR140E RAM Replacement: Schritt 5, Bild 1 von 2 Sony Vaio VGN-SR140E RAM Replacement: Schritt 5, Bild 2 von 2
    • Lift the thin black plastic cover to access the RAM.
  6. Sony Vaio VGN-SR140E RAM Replacement: Schritt 6, Bild 1 von 2 Sony Vaio VGN-SR140E RAM Replacement: Schritt 6, Bild 2 von 2
    • Apply light outward pressure to the locks on either side of the RAM. Rotate the RAM up slightly. Pull the RAM toward you to remove it.
  7. Sony Vaio VGN-SR140E RAM Replacement: Schritt 7, Bild 1 von 3 Sony Vaio VGN-SR140E RAM Replacement: Schritt 7, Bild 2 von 3 Sony Vaio VGN-SR140E RAM Replacement: Schritt 7, Bild 3 von 3
    • Using the same light outward pressure on the locks, lift the secondary RAM up and slide it away from you to remove it from its slot.
Abschluss
Jeremy
722 Reputation
4 Anleitungen geschrieben
Michigan Tech, Team 1-6, Lauer Spring 2015 Mitglied von Michigan Tech, Team 1-6, Lauer Spring 2015
MTU-LAUER-S15S1G6
2 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 474
