Zum Hauptinhalt wechseln
Sony Vaio VGN-SZ120P Optical Drive Replacement
Was du brauchst
  1. Sony Vaio VGN-SZ120P Optical Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Set the computer display-side down.
    • Unlock the battery by sliding the port-side latch to the 'unlock' position.
  2. Sony Vaio VGN-SZ120P Optical Drive Replacement: Schritt 2, Bild 1 von 1
    • On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
  3. Sony Vaio VGN-SZ120P Optical Drive Replacement, Keyboard: Schritt 3, Bild 1 von 1
    • Ignore the removal of the heat sink and memory panels as depicted. They do not need to be removed for the completion of this guide.
    • Remove the Torx security screw near the center of the battery-side edge.
  4. Sony Vaio VGN-SZ120P Optical Drive Replacement: Schritt 4, Bild 1 von 2 Sony Vaio VGN-SZ120P Optical Drive Replacement: Schritt 4, Bild 2 von 2
    • Press the tabs on each side of the display-side of the keyboard with the flat edge of a spudger.
    • Pull the keyboard toward the mouse pad and gently lift up.
  5. Sony Vaio VGN-SZ120P Optical Drive Replacement: Schritt 5, Bild 1 von 2 Sony Vaio VGN-SZ120P Optical Drive Replacement: Schritt 5, Bild 2 von 2
    • The keyboard is still attached by ribbon cable, don't try to remove the keyboard entirely yet.
    • Disconnect the ribbon cable by pressing the tabs on either side of the connector. Pull the cable out parallel to the connector.
    • Remove the keyboard.
  6. Sony Vaio VGN-SZ120P Optical Drive Replacement, Mouse Assembly: Schritt 6, Bild 1 von 1
    • Turn the laptop upside down.
    • Remove the three screws from the front mouse panel located on the bottom of the laptop.
    • Carefully flip the laptop back over. Remove three more screws from the top securing the panel. A ribbon cable will still be attached to the panel when you remove it.
  7. Sony Vaio VGN-SZ120P Optical Drive Replacement: Schritt 7, Bild 1 von 2 Sony Vaio VGN-SZ120P Optical Drive Replacement: Schritt 7, Bild 2 von 2
    • Lift the mouse assembly just enough to access the connecting ribbon cable.
    • Lift the ribbon cable lock to remove the cable.
    • Carefully remove the mouse panel assembly and set aside.
  8. Sony Vaio VGN-SZ120P Optical Drive Replacement, Optical Drive: Schritt 8, Bild 1 von 1
    • Remove the securing screw on the bottom left of the optical drive.
  9. Sony Vaio VGN-SZ120P Optical Drive Replacement: Schritt 9, Bild 1 von 1
    • Carefully slide the optical drive out right.
    • The IDE connector on the left will pop out.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
David Hoyt
4.023 Reputation
43 Anleitungen geschrieben
Cal Poly, Team 25-89, Amido Spring 2010 Mitglied von Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Mitglieder
63 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 5,367
