Zum Hauptinhalt wechseln
Sony Vaio VGN-Z48GD SSDs Replacement
Was du brauchst
  1. Sony Vaio VGN-Z48GD SSDs Replacement, SSDs: Schritt 1, Bild 1 von 1
    • Power off your laptop before starting.
    • Disconnect all external cables from the device.
  2. Sony Vaio VGN-Z48GD SSDs Replacement: Schritt 2, Bild 1 von 1
    • Flip the device over so that the battery is facing away from you.
    • Unlock the battery by using your finger to push the "Lock" latch to the right.
    • You will hear a soft click when the latch has been disengaged.
  3. Sony Vaio VGN-Z48GD SSDs Replacement: Schritt 3, Bild 1 von 1
    • Place your finger on the "Release" latch.
    • Slide the latch to the right and hold it.
    • Use your other hand to lift the battery from the groove.
    • Remove the battery.
  4. Sony Vaio VGN-Z48GD SSDs Replacement: Schritt 4, Bild 1 von 1
    • Remove a 5 mm Phillips #000 screw from the RAM cover located in the centre of the device.
    • Remove the RAM cover.
    • There is no need to remove the RAMs as they won't get in the way.
  5. Sony Vaio VGN-Z48GD SSDs Replacement: Schritt 5, Bild 1 von 2 Sony Vaio VGN-Z48GD SSDs Replacement: Schritt 5, Bild 2 von 2
    • Remove the following eleven screws:
    • Five 13 mm Phillips #000 screws
    • Six 5 mm Phillips #000 screws
  6. Sony Vaio VGN-Z48GD SSDs Replacement: Schritt 6, Bild 1 von 1
    • Flip the device and open the lid so that the keyboard is facing upwards.
    • Use an opening tool to lift the keyboard assembly slightly.
    • Make sure you don't lift the keyboard assembly too much as there is a ribbon cable in between.
  7. Sony Vaio VGN-Z48GD SSDs Replacement: Schritt 7, Bild 1 von 1
    • Flip the keyboard assembly towards you.
  8. Sony Vaio VGN-Z48GD SSDs Replacement: Schritt 8, Bild 1 von 1
    • Use an opening tool to pry the keyboard assembly connector up from its socket on the motherboard.
    • Remove the keyboard assembly.
  9. Sony Vaio VGN-Z48GD SSDs Replacement: Schritt 9, Bild 1 von 1
    • Use an opening tool to pry the uSATA ribbon cable connector up from its socket on the motherboard.
  10. Sony Vaio VGN-Z48GD SSDs Replacement: Schritt 10, Bild 1 von 2 Sony Vaio VGN-Z48GD SSDs Replacement: Schritt 10, Bild 2 von 2
    • Remove two 13 mm screws from the SSD bracket using a Phillips #000 screwdriver.
    • Remove the SSD bracket.
  11. Sony Vaio VGN-Z48GD SSDs Replacement: Schritt 11, Bild 1 von 1
    • Flip the SSD bracket.
    • Use your hand to disconnect the uSATA connector on the right.
  12. Sony Vaio VGN-Z48GD SSDs Replacement: Schritt 12, Bild 1 von 1
    • Use your hand to disconnect the uSATA connector on the left.
    • Remove the uSATA ribbon cable.
  13. Sony Vaio VGN-Z48GD SSDs Replacement: Schritt 13, Bild 1 von 1
    • Remove two 2 mm Phillips #00 screws.
  14. Sony Vaio VGN-Z48GD SSDs Replacement: Schritt 14, Bild 1 von 1
  15. Sony Vaio VGN-Z48GD SSDs Replacement: Schritt 15, Bild 1 von 1
    • Take out the SSDs from the bracket.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Vincent L
265 Reputation
1 Anleitung geschrieben
York University, Team S3-G51, Melo-Thaiss Fall 2020 Mitglied von York University, Team S3-G51, Melo-Thaiss Fall 2020
YORK-MELO-THAISS-F20S3G51
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 34
Insgesamt: 1,049
