Zum Hauptinhalt wechseln
Sony Vaio VPC-Y2190X Hard Drive Replacement
Was du brauchst
  1. Sony Vaio VPC-Y2190X Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip your laptop so that the bottom is facing up.
  2. Sony Vaio VPC-Y2190X Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Slide the “Lock” switch to the right.
    • Slide and hold the “Release” switch to the left.
  3. Sony Vaio VPC-Y2190X Hard Drive Replacement: Schritt 3, Bild 1 von 2 Sony Vaio VPC-Y2190X Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • While holding the “Release” switch, lift the lip of the battery.
    • Lift the battery up and out of the laptop.
  4. Sony Vaio VPC-Y2190X Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 1
    • Using a #0PH screwdriver, unscrew the three 4.80mm screws on the back of the device.
    • The screws are held into the panel by washers, they will not fall out once unscrewed.
  5. Sony Vaio VPC-Y2190X Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Remove the panel.
    • Use the #0PH screwdriver to remove the four 3.61mm screws.
  6. Sony Vaio VPC-Y2190X Hard Drive Replacement: Schritt 6, Bild 1 von 2 Sony Vaio VPC-Y2190X Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Carefully lift the hard drive.
    • Remove the hard drive by pulling it to the left.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 366
