Zum Hauptinhalt wechseln
Sony Vaio VPCCB290X Keyboard Replacement
Was du brauchst
  1. Sony Vaio VPCCB290X Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    Kaufen
    • Attach an anti-static wrist strap to a piece of metal to prevent possible short circuiting.
    • Use a spudger to press in the black clips that lock the keyboard in place.
    • As you press in the black clips, remove the screws near the motherboard using the screwdriver.
    • Do not remove the motherboard.
  2. Sony Vaio VPCCB290X Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Using the metal spudger, pick a corner and carefully begin to pop off the keyboard.
    • It is normal to hear a soft clicking sound as the keyboard releases from the device.
  3. Sony Vaio VPCCB290X Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Two cables are attached to two white inserts to keep the keyboard anchored in place once the clips have been removed, and to keep the keyboard attached to the motherboard.
    • Unplug the thin cable by just simply pulling the cable straight out of the connector.
    • Leave the thicker white cable alone.
  4. Sony Vaio VPCCB290X Keyboard Replacement: Schritt 4, Bild 1 von 2 Sony Vaio VPCCB290X Keyboard Replacement: Schritt 4, Bild 2 von 2
    • To fully release the old keyboard, lift the black wedge clip by using the spudger tool to press down on the clip and release the wider cable.
Ziellinie
Eric Martinez
637 Reputation
6 Anleitungen geschrieben
USF Tampa, Team 20-5, Remmell Spring 2017 Mitglied von USF Tampa, Team 20-5, Remmell Spring 2017
USFT-REMMELL-S17S20G5
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 625
