Zum Hauptinhalt wechseln
Sony Vaio VPCCB290X LCD Screen Replacement
Was du brauchst
  1. Sony Vaio VPCCB290X LCD Screen Replacement, LCD Screen: Schritt 1, Bild 1 von 1
    • First make sure the laptop is off and closed.
  2. Sony Vaio VPCCB290X LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Unlock the battery and push the release lever to remove the battery from the laptop.
  3. Sony Vaio VPCCB290X LCD Screen Replacement: Schritt 3, Bild 1 von 2 Sony Vaio VPCCB290X LCD Screen Replacement: Schritt 3, Bild 2 von 2
    • Remove the screws marked in red to remove the hard drive cover and the screws marked in blue to loosen the hard drive. Then gently slide the hard drive out.
  4. Sony Vaio VPCCB290X LCD Screen Replacement: Schritt 4, Bild 1 von 1
    • Remove all the screws that hold the plastic bottom on. There are some more screws that cant be seen in the photo.
  5. Sony Vaio VPCCB290X LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Gently pry up the plastic bottom and if it feels like it is resisting check the surrounding areas for more screws.
  6. Sony Vaio VPCCB290X LCD Screen Replacement: Schritt 6, Bild 1 von 1
    • Now that the backing plate is off make sure to be careful of the Motherboard and its components from being damaged. from here on out it is recommended that you wear a anti static bracelet or at the very least touching something metal to remove any static electricity that you may have built up
  7. Sony Vaio VPCCB290X LCD Screen Replacement: Schritt 7, Bild 1 von 1
    • Use a common or lat head screw driver to gently untangle the wires from their paths.
  8. Sony Vaio VPCCB290X LCD Screen Replacement: Schritt 8, Bild 1 von 2 Sony Vaio VPCCB290X LCD Screen Replacement: Schritt 8, Bild 2 von 2
    • You will need to unscrew this small circuit board and fold it up to get the wires out from under it.
  9. Sony Vaio VPCCB290X LCD Screen Replacement: Schritt 9, Bild 1 von 1
    • Disconnect the screen from the motherboard.
  10. Sony Vaio VPCCB290X LCD Screen Replacement: Schritt 10, Bild 1 von 1
    • They are two hinges that hold the screen on. Make sure to pay attention to where the screws come from in order to put them back and to make installation easier.
  11. Sony Vaio VPCCB290X LCD Screen Replacement: Schritt 11, Bild 1 von 1
    • By folding up the hinges the screen will simply slide away from the body of the computer and you can then put the new screen into place.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Eric Martinez
637 Reputation
6 Anleitungen geschrieben
USF Tampa, Team 20-5, Remmell Spring 2017 Mitglied von USF Tampa, Team 20-5, Remmell Spring 2017
USFT-REMMELL-S17S20G5
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 787
